DD2003 Results
Old Jul 29, 2005 | 10:23 PM
eric9c1's Avatar
DD2003 Results
Hey, I tried to build a stock LT1 file using Desktop Dyno 2003 and add some mods to it.. heres what I did
Used the pre-made file GM_SBC_372_Aluminum LT1 Heads with 1.94 intake and 1.50 exhaust valves
10.4:1 CR but its showing 76cc on the heads? I dont know how to change it to 54cc (that is correct for stock lt1 aluminums right?)
Induction I have 800cfm gasoline engine, and Forced Induction (Vortech V2-S blower at 6psi) and 50% intercooler efficiency
cam: lift w/1.6rr 0.535/0.544 intake 224/236 @ 114lsa and "roller hydraulic lifters"
The numbers I show are
2000 RPM 175 / 459 tq
3000 RPM 285 / 499 tq
4000 RPM 391 / 513 tq
5000 RPM 473 / 497 tq
6000 RPM 503 / 440 tq
What do you guys think of the accuracy of these numbers?
Old Jul 30, 2005 | 12:45 AM
1racerdude's Avatar
Re: DD2003 Results
That might be close with the blower.DDD isn't very accurate and ya got the inputs messed up.
It is telling ya flywheel HP.
Old Jul 30, 2005 | 12:59 AM
eric9c1's Avatar
Re: DD2003 Results
Yes, I know that is flywheel hp because it is an engine sim, sorry i didnt say it.
What inputs are messed up?
Old Jul 30, 2005 | 01:07 AM
1racerdude's Avatar
Re: DD2003 Results
It's telling ya it has 76CC heads. The inputs on these programs have to be accurate to get a good HP figure.
Garbage in garbage out.
I have EAP and one of Lockheed's old Pro Stock programs and if the inputs are not correct it might tell ya anything.
HAWG
Sep 25, 2015 11:41 AM
Aug 17, 2015 09:50 AM
Boss002
Jul 24, 2015 10:47 AM
