I smell gas
Old Jul 26, 2005 | 10:36 PM
ZU_LTR's Avatar
Question I smell gas
I noticed that after driving for a while when I come to a stop I smell gas . I don't know if it's because my car is running rich or what. I don't see any fuel leaks anywhere so I was just wondering if anyone else has the same situation . it's not an overpowering smell it's just noticeable. any thoughts or suggestions would be appreciated. thanks..
oh yeah my car is a 95 Z28..
MY Z28
Old Jul 26, 2005 | 10:40 PM
lt11997's Avatar
Re: I smell gas
Is the smell strongest by the driver side rear quarter panel?
Old Jul 26, 2005 | 10:46 PM
ZU_LTR's Avatar
Re: I smell gas
I couldn't really say, I smell it most on the driver side when i have my window down.
Old Jul 26, 2005 | 10:56 PM
lt11997's Avatar
Re: I smell gas
It's probably from the EVAP canister, but I would double check to make sure you don't have a fuel leak.
Old Jul 26, 2005 | 11:01 PM
Lt1t56's Avatar
Re: I smell gas
One other thing to check is the gas cap, I had a fuel smell and it was coming from the gas cap (rubber O ring was coming apart)
Old Jul 27, 2005 | 01:35 PM
ZU_LTR's Avatar
Re: I smell gas
It's not my gas cap and I don't see any leaks. any more suggestions.
could it be comming from the exhaust ,because it smells like evaporated fuel and it's not constant . like when I get into my car for the first time in the morning I don't smell gass. It usually comes after driving .and I smell it most when i'm stopped. anyones help is appriciated .. thanks!
MY Z28
Old Jul 27, 2005 | 02:00 PM
tfs95z28's Avatar
Re: I smell gas
if you dont smell it on initial start up i would say its not in your exhaust. Usually when you start a car up you will smell it in the exhaust pretty good if you are running rich or just because. I know i smell it in my exhaust because of my cam.
Old Jul 27, 2005 | 02:36 PM
TTlord's Avatar
Re: I smell gas
i have the same problem from time to time. i think it is my car running rich. it usually comes up from under the car. i also had a problem with my gas cap comming unscrewed. i would fill it up and put it on untill it clicked and then take off. awhile later i would have gas down the side of my rear quarter. i would check it and the cap was loose. so i would retighten. so now i dont completely fill it up. i am goping to have a friend that works at a local chevy dealer look into a new cap for me.
Old Jul 27, 2005 | 04:26 PM
Deenasty's Avatar
Re: I smell gas
is this the canister that is behind the plastic inner quarter panel, panel? I have this same issue, and Im not sure if its that, or my gas cap
Old Jul 27, 2005 | 05:02 PM
ZU_LTR's Avatar
Re: I smell gas
MY Z28
I don't smell fuel when I get in my car, but I do after I start it .
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bails098
Aug 17, 2015 05:15 PM
