CC306 and no tune.. How will it run? Mines going nuts!
Old Feb 13, 2004 | 10:54 PM
CoUnTryMuZiCZ28's Avatar
I took the beast out for a drive today and the car was idling fine, when you press the gas and the release the idle drops really low and then picks back up..
there is no rocker noise and they are adjusted perfectly..
I was doing about 120 and then slowed to a light and the car dropped to about 400 RPM idle ... So i shut the car off and started it again at the light and then it idled fine, went up to about 110 and slowed down and it did it again... sounded like it was about to die, but didnt..
SES light goes on and off, idle changes with light...
Hesitates really really bad down low but at 2000 it smoothes out and pulls hard even under normal accel..
Cruising it jerks around a bit (car)..
Under heavy down shifts the car sounds like its got a hollow exhaust and starts rappidly back firing..
Is this all normal on a base LT1 edit tune (fuel curves were lowered with the tune.. then the cam went in like 5 months later.. the tune wasnt for the cam is what im trying to say.. its pretty much a stock comp...
Starts and idles great..
Letting off the clutch it wants to die really bad..
Coolant temp goes up ALOT almost to redline!
SOOOO what do you guys think?? Im getting my comp tuned this week... I just wanna know if this is normal..... had some detonation too i think but i put some octane booster in and poof it was gone.. lol
Old Feb 13, 2004 | 10:58 PM
Sleeper_Z's Avatar
Im not positive but it seems strange to me. My buddy went out and turned 12.5s on his stock tune with an AUTO. His car didnt really act up at all other than some surging and the idel dipped when jumping out of the throttle. But all in all it was ok to drive on.
Old Feb 13, 2004 | 11:06 PM
Z95m6's Avatar
i think you need to drill out your IAC. Mine would almost die when you slowed down, and would almost stall out when you turned the AC on and that was with a H/C tune.
Old Feb 13, 2004 | 11:12 PM
What do you mean drill out the IAC?? Its also fine when you first start it up.. when the car goes into its loop thing and the ses light goes on is when everything happens..
It also stays at like 1500 to 2000 sometimes after a quick rev or drive.. like if you drive then stop, it takes about 3 or 4 seconds for the idle to go down
Old Feb 13, 2004 | 11:13 PM
Z95m6's Avatar
do a search on drilling out the IAC. I don't remember what size drill bit to do. Me and my friend both did it and it helped our cars bunches.
Old Feb 13, 2004 | 11:23 PM
I have one of those little air foil things.. Could that be blocking the IAC???
Old Feb 13, 2004 | 11:26 PM
Sleeper_Z's Avatar
Try just taking it out and see what happens. Easy 5 min job.
Old Feb 14, 2004 | 12:33 AM
Do i need to take my TB off to do this? (drill iac)
Old Feb 14, 2004 | 12:34 AM
TMorgan800's Avatar
I've got a cc306 program if you need one.
is yours stick or auto?
--troy
Old Feb 14, 2004 | 12:35 AM
Stick... what do you mean? youll load it to my comp?
Old Feb 14, 2004 | 12:38 AM
lt1g3n's Avatar
damn
damn , i had my pcm tuned for the cc306, and then i ended up getting the 305, am i going to have trouble too?? should i take it back in?
Old Feb 14, 2004 | 01:14 AM
TMorgan800's Avatar
no, i can send you a bin file though..
Old Feb 14, 2004 | 02:19 AM
I dont have anything to tune it with
Old Feb 14, 2004 | 09:23 AM
Ok update... I took the air foil out and the car idles much much smoother... Im going to drill the iac out of the air foil so it can breathe and put the air foil on.. Now i have the coolant problem... It goes up to about red line... Why !
Old Feb 14, 2004 | 09:53 AM
Cmr0z28's Avatar
Are you sure you installed the radiator/cooling fans and all that good stuff properly?
