When You Torqued Down Your Heads
Old Feb 13, 2004 | 07:20 PM
ibanez6rg's Avatar
Did it feel like you were applying that much torque at all?
I just did 25, 45, 65 ft.lbs. and I felt like I could do it with my pinky... almost.
Old Feb 13, 2004 | 07:25 PM
fastbird96's Avatar
Yes, but keep in mind that most torque wrenches have a long handle which gives you a lot of leverage. The bolts are tighter than what you think.
Old Feb 13, 2004 | 07:39 PM
FastZinTennessee's Avatar
Maybe it was because I was torquing with the motor in the car, but it felt like I was applying a lot of pressure.
<no sissy jokes fellas!!!>
Old Feb 13, 2004 | 07:44 PM
ibanez6rg's Avatar
I'll probably check them again after I torque down the rockers studs... How many ft. lbs. on those?
It seriously felt like nothing!
Old Feb 13, 2004 | 07:48 PM
stereomandan's Avatar
Sure it was foot pounds (ft. lbs) that you had the torque wrench set at, and not inch pounds (in. lbs.)?
Dan
Old Feb 13, 2004 | 07:49 PM
Cmr0z28's Avatar
It's cause you're so jacked.
Old Feb 13, 2004 | 07:51 PM
ibanez6rg's Avatar
That may be...
Definitely foot pounds.
Old Feb 13, 2004 | 09:35 PM
50 on the rocker studs. Hopefully, your torque wrench is in good calibration.
Old Feb 13, 2004 | 10:42 PM
S.J.S.'s Avatar
Banester just get off them damn ROIDs! I told you about that. That sheeeit is gonna kill ya.
Old Feb 13, 2004 | 10:50 PM
ibanez6rg's Avatar
Should be, fairly new. I hope.
Old Feb 13, 2004 | 11:20 PM
Z95m6's Avatar
I would say its probably just a big torque wrench. The wrench i use is big enough that i can do 100ft lbs. no problem and it hardly feels like anything at all.
Old Feb 13, 2004 | 11:27 PM
Buttercup's Avatar
If it was that easy I'd be worried about overstrained bolts. Are these new bolts or are you reusing some? If you are reusing the stock bolts this could very well be a problem!
I don't care how long your torque wrench is or how big your pinky is... it shouldn't be THAT easy.
Old Feb 14, 2004 | 02:42 AM
scoobysnax83's Avatar
Mine were extremely easy, but my tq wrench was like 1.5 feet long
Old Feb 14, 2004 | 03:41 AM
atljar's Avatar
Toque wrench? Just impact them tight.
JUST KIDDING FELLAS!
Old Feb 14, 2004 | 03:45 AM
Wanna know a secret.. I torqued the top middle bolt down on the driver's side so hard that I stripped the head of the ARP bolt and was unable to back it off. I didn't here or feel the stupid tq wrench. But its been almost 5,000 miles and nah a problem. Odd, if you ask me. The rest of the bolts were tightened correctly. The reason that I kept tightening was for the above reason, just didn't feel like it could have possibly been enough.
