help with vats +key won't come out of igition
Old Feb 13, 2004 | 01:27 PM
sweet z28 99's Avatar
hi, well i had the vats problem awhile back and now its doing it again i am not sure if the resistor is loose i am going to check but my question is about the key not coming out of the igition, when i turn the key it makes a churnching sounds and is really ruff turning also i already changed the igition switch (i think that what it was called) it was on top of the steering colom ect. if any one could help me out i would be greatful
thanks lt1 tech
Old Feb 13, 2004 | 02:04 PM
llafro's Avatar
Are you having problems with the ignition cylinder turning with the key in it? Make sure first off that the key you have is not worn. Overly worn keys can make the cylinder hard to turn. Basically, it acts like it's almost the wrong key, making it hard to turn. If the key is not worn, then there may be a problem with the lock mechanism internally. That would require replacing the cylinder.
Old Feb 13, 2004 | 02:33 PM
hi, thanks for th help i will check that out today anyone else have any ideals what could be wrong?
Old Feb 13, 2004 | 05:41 PM
ttt
Old Feb 13, 2004 | 09:42 PM
coem on guys its my every day driver
Old Feb 13, 2004 | 09:54 PM
Eliminator's Avatar
I dont know if this will help this is the only thing that I heard will make the key get stuck sorry if this dont help. Click link.
http://shbox.com/trans/park_lock.html
Old Feb 15, 2004 | 10:27 PM
thanks for all the help but i have no clue whats going on with it.
Old Feb 16, 2004 | 12:44 AM
GreenDemon's Avatar
Sounds like fun, I have the same problem, sort of. As long as I don't use the acc position I don't have any problems, though.
As a quick fix you could try some graphite lube and see if that smoothes things out a bit, it worked wonders on mine.
If that doesn't work, well, you'll just need a new key or a new cylinder- kinda sucks but not much else you can do...
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
Hal Fisher
Sep 30, 2015 09:03 PM
colts0455
Sep 27, 2015 01:07 PM
KYWes
Sep 26, 2015 08:49 AM
