Extra Wires??
Old Feb 13, 2004 | 01:32 PM
All4Chevy's Avatar
Extra Wires??
Long story short, because i jsut typed it and the next page wouldn't load so now im re-typing it. Behind my brake pedal is a short wire that hangs about 3 inches above the actual pedal. You can only see it if you head is on the floor by the pedal and look up. It has 2 wires goign to a white female connector. One wire is grey, one is black/grey striped. Does anybody know what it is supposed to go to??
Bill
Old Feb 13, 2004 | 04:16 PM
Pretty sure it would go to the clutch anticipate/cruise release switch.
Old Feb 14, 2004 | 11:15 AM
All4Chevy's Avatar
Ok i just got the bottom dash piece off so i could actually see whats going on down there. The clutch sensor and brake sensor that are for the cruise control are already plugged in. They have a red wire and a black wire goign to each. The one im looking at has a tan wire and a black/white wire. I cant see anywhere it would go. Its from the same harness at the other wires (they are all taped together) but its fairly short, maybe 3 or 4 inches, so it cant reach too far....
This is really annoying.
Bill
P.S. any chance this could be an extra wire made for automatics that is just left there on manuals???
Old Feb 14, 2004 | 11:49 AM
All4Chevy's Avatar
Shoebox, i just found this post on the same subject... to my knowledge they do not have an answer either...however here is a picture for you to see what I am talkign about http://community.webshots.com/album/94364657FKHgPP
Thanks though
Bill
Old Feb 14, 2004 | 12:12 PM
Well, when I looked at the manual, it showed those very colored wires for the switch I said. I don't have a manual trans car, so I can't go from that. I do seem to remember that there might be an unused connector between the auto and manual cars. Is everything working ok or is there a problem?
Old Feb 14, 2004 | 12:18 PM
All4Chevy's Avatar
Yes i was just reading about the unused wires... The only problem i have is that cruise control stopped working and my ABS light comes on after a few feet of driving, but i believe that to be my rear sensor. I emailed the person who had the same connector issue to see what he found out, for now im goign to 'assume' that it is an unused wire. It looks like rains coming so i had to put the car back together too
Bill
Old Sep 3, 2007 | 04:18 PM
GMH94Z28's Avatar
Did you ever find out where that tan wire went to?
Jazsun
Dec 29, 2014 12:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
Jul 4, 2005 05:00 PM
