2bolt or 4 bolt
Old Feb 12, 2004 | 11:27 AM
lt1g3n's Avatar
2bolt or 4 bolt
jeez i didnt even bother to check or really how to check
2 bolt main block or 4 bolt main block for the lt1s i guess are the two.. how do i tell which i have--- when i bought the block new it had cast iron heads on it , so it prolly came out of a impala , roadmaster, or something like that... how do i check now that its in the car? and i hear 2 bolts arent the greatest =/ hopes for the best ;p
Old Feb 12, 2004 | 11:32 AM
lt1g3n's Avatar
i dont even know if it came out of one of those, but what i meant to say is that it's the motor that was used in those cars prolly, because the block is like brand new, seemed only to be started once to check if it was good, everything is perfect.
Old Feb 12, 2004 | 11:49 AM
GREGG 97Z's Avatar
It's most certainly a 2 bolt block if it came out of an Impala or Roadmaster and had iron heads. All Fbody LT1's were 2 bolt blocks with the exception of around 129 1997 LT4 cars. All Corvette LT1's came with 4bolt mains though. Are you sure you got an LT1 though? Some of those cars you mentioned came with the L99 4.3 V8 which looks just like the LT1, some call it the "baby" LT1. If it's out of an Impala SS it would be a LT1 with iron heads, but I think a lot of regular Imps, Caprices and Roadmasters had the L99, not positive though.
Old Feb 12, 2004 | 12:25 PM
lt1g3n's Avatar
its certainly a lt1, it says 5.7 on it, and everything else matches specs... but ya 5.7 is stamped on the block.
Old Feb 12, 2004 | 05:22 PM
94m5's Avatar
Whats the casting number off of the back of the block? Look at the flange where the tranny bolts it, and there should be a 7 or 8 digit number. I can't remember which. You can tell what you have from that.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
