WTF!!! car dies when put into gear!!!
Old Feb 15, 2004 | 08:53 AM
gsdz28's Avatar
Car dies when put into gear!!!
You can see my mods below, and it is .......or was tuned.
the only recent additions to the car were functional ram air, and a alternator overdrive pulley.
it was cold, let the car warm-up for like ten minutes, put into reverse the rpm's dropped and it died......same when i put it into drive!!!!! so i foot braked it and got it into gear and my rpm's were at like 600 !!!!!!!! drove it to work no problem. once i was there i startred put it in and out of reverse and OD no problems!!!
what is going on???????
Old Feb 15, 2004 | 09:17 AM
Did you have the battery disconnected (maybe when you worked on the alternator)? If so, it takes the pcm time to relearn what was erased. It's normal for you to have some slight drivability problems until it relearns in all cells.
If you will indulge me, WTF is way annoying and offensive. I think this may be the last post I will reply to that has that in the content.
Old Feb 15, 2004 | 09:44 AM
gsdz28's Avatar
my bad... i deleted the WTF's
no battery was not disconnected, when we did the pulley
Old Feb 15, 2004 | 10:55 AM
roadtrip120's Avatar
IS it a manual??
might be the clutch / slave cylinder
Old Feb 15, 2004 | 11:38 AM
5.7LT1Formula's Avatar
If it is an Auto could be the Trans/converter issue?? i had the same problems w/ my SUV when i bought it used and abused.
Old Feb 15, 2004 | 11:42 AM
gsdz28's Avatar
It is and auto, and I would think if it was a trans or converter issue i would have a SES light?????
Old Feb 15, 2004 | 01:15 PM
hazard2k's Avatar
My winter car (93 grand am GT) was acting similar to yours ealier and it turned out to be a vacuum hose was somehow cut so i replaced it and it ran fine.. Dont know if thats your problem, but it would be a easy thing to check.
97SSdude
Dec 31, 2014 07:43 PM
ModdedNerd
Dec 18, 2014 10:52 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
