Car won't idle
Old Feb 14, 2004 | 05:44 PM
96ta(nick)'s Avatar
Car won't idle
runs fine but when i come to a stop the idle drops to 500 and then goes back up after a few seconds? what gives? it is tuned and has heads/cam
Old Feb 15, 2004 | 12:40 AM
indieaz's Avatar
Tuned by who? I'm suspecting rockers could ba djusted too tight causing it to not be able to idle properly (this would be the most common cause). Other than that likely tuning doens't have the idle set high enough - most peope have their warm idle around 800 rpm that i talk to with even mild cams. Check your valve lash first and make sure those rockers aren't too tight.
Old Feb 15, 2004 | 01:05 AM
96ta(nick)'s Avatar
i think they are because it is backfiring a bit, i will readjust them in the morning and it was tuned by pcmforless. It is also pig rich and throwing a code, is suspect it is the o2 sensors but i will have to wait untill autozone opens in the morning to find out.
bfmv13trivium
Jan 14, 2015 09:57 AM
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
