4 bolt splayed caps ? wich ones to use?
Old Feb 13, 2004 | 01:48 PM
charles94ta's Avatar
Who makes 4 bolt splayed caps for LT1 blocks?
Do the ones for old small blocks fit?
thank you for your responses
Old Feb 13, 2004 | 02:48 PM
Pro-Gram Engineering
Old Feb 13, 2004 | 02:50 PM
dreamer1q's Avatar
My Olivers worked very nice as well
Old Feb 13, 2004 | 10:33 PM
Steve in Seattle's Avatar
Do your Oliver ones look like the Pro-Gram versions?
Pro-Gram lists the following contacts/links in the US:
Oliver Racing Parts
1025 Clancy Ave. NE
Grand Rapids, MI 49503
Ph. 800-253-8108
http://www.oliver-rods.com
Might want to do a search in the Advanced forum, I believe there is an issue with some splayed caps interfering with the dip-stick tube. Of course it really depends on the brand more than anything else, but I'd imagine the smaller the splay angle, the better the chance of clearance.
GMPP makes some billet straight-4-bolt caps as well BTW.
Old Feb 14, 2004 | 12:55 AM
rskrause's Avatar
Moderator
I am using the Pro-Gram straight billet caps this year. Seems like nice pieces. Callies recommended them.
Rich Krause
Old Feb 14, 2004 | 09:29 AM
SStrokerAce's Avatar
I have two motors in the shop right now, one has Pro Grams on it and the other has Oliver caps on it.
IMHO the Olivers are a better design and higher quality, but they might give you a slight problem with the dipstick. The Oliver's I am using are a 4 bolt direct replacement cap, so the outer bolts are straight up and down not splayed. So less dipstick problems than a standard splayed cap.
Bret
Old Feb 14, 2004 | 09:55 AM
Mike383LT1's Avatar
splayed caps
I used the milodon, nice caps.
Old Feb 14, 2004 | 10:05 AM
thanks guys !
i will do a search because i am pretty sure the pros-cons of splayed vs straight bolts have been discussed already. but if you have facts, feel free to post them.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
