where is the pcm fuse??
Old Feb 11, 2004 | 09:51 PM
SiDeWaYZz28's Avatar
hey everybody i yhave a sefvice engine light on..and i was wondering where the fuse is for the pcm so i can reset it to see if the light goes away...and when i take it out do i turn the key on but dont start the car??thanks for the info
Old Feb 11, 2004 | 10:34 PM
Question
so nobody know????
Old Feb 11, 2004 | 10:36 PM
Red96Lt1's Avatar
I don't think the PCM has a fuse. But to reset the SES light, disconnect the battery.
Old Feb 11, 2004 | 10:46 PM
Originally posted by SiDeWaYZz28
so nobody know????
On a 1994, look for the PCM BATT fuse in the fuse panel on the left side of the dash.
Old Feb 11, 2004 | 10:49 PM
ok thanks shoe box i think its fuse #4
Old Feb 11, 2004 | 10:51 PM
JodyJ's Avatar
As Shoebox mentioned above, but when are you looking at the fuses itself. It's the bottom left hand corner fuse. I think it's the blue 15 amp fuse.
Jody J.
Old Feb 11, 2004 | 10:52 PM
thnaks when i pull it do i start the car or do i turn the key but dont start the car??i just want to reset it
Old Feb 11, 2004 | 10:55 PM
The car will not start with it out. Just pulling the fuse does the reset. Give it about 10 seconds and put it back in.
Old Feb 11, 2004 | 10:56 PM
JodyJ's Avatar
I usually just take out the fuse for about 2 mins with NO key in the ignition. I tried 30 & 45 seconds, but it didn't fully reset the PCM, I still had trouble codes.
Jody J.
Old Feb 11, 2004 | 11:13 PM
Jody J.
Hmmmmm..... #4, upper right corner, red 10A. Are the Z's and the Pontiac's different in 94? Did they flip the panel over?
PS: How did we know he was asking about a 94?
Old Feb 11, 2004 | 11:18 PM
As it turns out, the fuse boxes between the Camaro and Firebird are flipped 180º . The fuses are numbered the same, but one is upside down from the other. Strange, eh?
I looked at his website for the car info. I guess it was easier than asking. <shrug>
Old Feb 11, 2004 | 11:50 PM
Very strange......
I'm at the point where I'm not even going to bother with questions that don't include a signature, with the basic info like year of the car
Old Feb 12, 2004 | 12:23 AM
i have all my info on my page so i dont use hella room with a long sig
Old Feb 12, 2004 | 08:02 AM
MHO is not directed solely at you, but here it is:
It does not take but a few characters to indicate"94Z M6" or whatever. The glory list can be saved for the web page if not directly pertaining to the post. The people that it irritates the most are probably the one that answer a lot of questions and want to provide an intelligent answer. Those are the people you want to respond to your posts.
Time is valuable to a lot of folks and having to jump to other web pages and maybe having to wait for them to load and then getting attacked by zillions of pop-up ads (not that yours does)...it can get aggravating.
The easier you make it for people to help you, the better it is for you.
Old Feb 12, 2004 | 12:01 PM
ok no problem imma change my sig check it out......thanks guys
Jeff1904
Jun 5, 2016 05:00 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
