Girdle For the Rear? Going with Et Streets!
Old Feb 13, 2004 | 09:51 AM
96redformula7's Avatar
Since I am going with Et Streets I figure that I should spend the extra $150 and get a girdle as well as extra insurance. Think it would be worthwile?
Old Feb 13, 2004 | 10:01 AM
Chris'SS #2152's Avatar
Wouldn't hurt any.
Old Feb 13, 2004 | 10:02 AM
Sure it could hurt me. $150 Bills
Old Feb 13, 2004 | 10:17 AM
magius231's Avatar
well...yeah it might help some, but probably not enough to keep your rear end together if you get good traction having an A4 definitely helps though...I would say its probably a crap shoot either way
Old Feb 13, 2004 | 10:21 AM
GREGG 97Z's Avatar
I think it's helped hold my rear together so far. That along with a bearing stud kit and a solid pinion spacer are a good way to help beef up the 10 bolt. If I ran ET streets at the track with the M6 though I think my rear would be dead by now, I wont run them until I get a 12 bolt. A little slippage with the BFG dr's is better than a broken rear for me right now
Old Feb 13, 2004 | 05:14 PM
What is the point of a solid spacer and how much does it cost? How about the install?
Old Feb 13, 2004 | 05:20 PM
flyinZ's Avatar
I THINK the solid spacer keeps the pinion from "walking" up the ring gear..(keeps it in place) and they usually cost under $20...
Old Feb 13, 2004 | 06:08 PM
Chris 96 WS6's Avatar
The solid spacer replaces the crush sleeve. When you drop big power on launch, the crush sleeve can compress and crush more....which ends up opening up your backspacing on the gears. the solid spacer eliminates this, but to keep your pinion nut from backing off you'll have to have the nut brazed on.
Old Feb 17, 2004 | 09:10 AM
Well i ordered the ET streets AND a MAC Rear End Girdle to Help some. I am not planning on doing big drops so I don't think I will have problems.
Old Feb 17, 2004 | 09:22 AM
Gripenfelter's Avatar
Its harder to break the rearend with the A4 because when you brake torque a bit it preloads the rearend. You can't do that with manual.
I ran ET streets for 3 months last year. No problems.
Old Feb 17, 2004 | 09:49 AM
Me too. I ran ET streets all season last year on the stock 3.23's, 2800 Vig converter that flashes to 3000 behind my 362hp on the way to 1.72 60fts....rear is still quiet like when it was stock.
I am planning on a rear girdle too though....I think for the price it just makes sense and I'd rather spend some money now preserving the 10 bolt than blow $2300 on a 12 bolt setup. You can rebuild the 10-bolt 5-7 times for that price.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
