LT1 block only good til 500 fhp?
Roommate tryed to tell me that the ol' iron block is only good until 500 flywheel hp? I know that can't be true but let me know what you guys think?
Michael
Michael
If thats true, then there are plenty of people on here whos engines should have given up along time ago. That ol' iron block is plenty strong enough for more than that. The only weak spot is the 2 bolt mains, which are plenty strong for RPM use up to what the factory sets as the RPM limit. However, revving past that for prolonged periods of time is what will do in the engine. Other than that, she is as stout as they come.
Hmmm........LS1's are aluminum and LT1's are iron block. Do you want to point out to him that when Ford put the Supercharger on the new Cobra they switched it back to an Iron block? LS1's are mean and can take a lot, but if you get right down to it, I think iron is more durable.
I am sure someone will correct me if I am wrong.
No, I'm just kidding...
The "Block" itself is fine for almost any application on up like stated above. Its the valvetrain and internals that can't handle it.
Madman, Baxter and Sikora have all made over 1,000 flywheelHP with LT1 blocks. I saw Baxter's after he pulled it out.... 1,125HP and 9.04@155mph in a 3,900# car wasn't fast enough for him. The block was a stock straight 4-bolt LT1, no fill, still in good shape and is being reused by someone else in an 1,100HP nitrous setup. He did decide to switch to a Dart Iron Eagle in order to make some serious HP......
It takes some serious $$ to even get close to the 1k hp level. You'll probably run out of money before you run out of block. And, if you break the block, you can get another one for pretty cheap.
From: Albuquerque,NM--5,600 feet above you sea-level cats
Originally posted by SVT Killer LV
stock 302 blocks are good for about 500 after that its time for a split down the lifter valley.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
