Under the intake fogger?
Old Feb 14, 2004 | 01:51 AM
WhtLT1's Avatar
Do they make anything like this for our cars? Or would that be something that would have to be put together? and you know what I'm talkin about, like something that feeds from the back, kinda stealth
Old Feb 14, 2004 | 03:35 AM
IDAREU's Avatar
A friend of mine actually has a setup like that lying around. I thought of buying it off him several times but just never could justify it. You have to drill two holes in the back of the block though to back of the lifter valley, I think he actually tapped it and ran a threaded insert through the block wall then connected the an fittings to that. Didn't leak at all, just kind of a pain to do...and forget about changing the jet size. If you are interested I can give him a call and find out more, if he still has it.
Old Feb 15, 2004 | 04:06 PM
WhtLT1's Avatar
Ya if you could get me some info on that, that would be cool, and I never thought about that, the whole tappin a line through the back of the intake, I was always worried about it leakin.
Old Feb 15, 2004 | 04:14 PM
atljar's Avatar
Ive thought about it....
Problems... Cant change jets
Something leaks, breaks etc, cant fix it until its too late. (ie fitting through engine)
I dont think i would run it through the block. I would run it through the intake and plumb everything under that oil shield (no idea what it is called) and have jets point up into ports. That way it shouldnt restrict NA flow much.
Also be totally hidden = nice.
Old Feb 15, 2004 | 04:34 PM
gb95zconv's Avatar
No need to go thru the block.
http://www.slammed98gmc.com/FNITRO003.jpg
mightymouse383
Jul 20, 2016 07:34 AM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
SAR2K
Sep 1, 2002 10:49 AM
