from what year to what year>cluster<
Old Feb 11, 2004 | 10:15 PM
BIGCOWL-IMP's Avatar
i have a 93 formula and want to put in a newer year gage cluster
but not sure on what year will fit and plug in with no modifing
Old Feb 11, 2004 | 10:21 PM
redthunder96's Avatar
I believe you could only go up to '95 because the switch to the OBDII was in '96 if I recall correctly.. Newer than that would require some modifying..
Someone correct me if I'm wrong, but I'm pretty sure thats the newest you could go...
Old Feb 12, 2004 | 07:57 AM
Zepher's Avatar
So, if you go from an ODBII pcm to an OBD1, do you need to change clusters too?
Old Feb 12, 2004 | 11:14 AM
Grover's Avatar
No.
Old Feb 12, 2004 | 11:42 AM
Fastbird93's Avatar
93-96 will swap no problem.
97 with the digital odometer will swap into earlier years no problems except the seat belt light will stay on constantly and so will the TCS OFF light if you don't have traction control.
I know, my purple pearl 93 has a 97 cluster in it.
98+ will not correctly swap into an LT1 car because of the gauge wiring. Gauges get funky.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
meissen
Jun 1, 2015 07:59 AM
capebuf
Jan 13, 2015 07:22 PM
ChrisFrez
Dec 28, 2014 02:25 PM
