quick cam install ? .. do you have to take the intake manifold off even if
you aren't replacing the lifters?
I would assume you do, to take the lifters out and also for the oil pump drive gear.
but if not necessary, I don't want to have to pull the manifold off.
I've never installed a cam before but if you were to remove the old cam, wouldn't the lifters fall down making it not possible to install the new cam unless you find a way to keep them held up?
Originally posted by 9T4LT1
I was under the assumption that the lifters were spring loaded and all you had to do was loosen the rocker arms to get the lifters to raise out of the way of the cam. I could be wrong........wouldn't be the first time
You MUST remove the lifters and the oil pump gear from the block to remove the cam and that means pulling the intake.
Originally posted by 96lt1Camaro
since we are talking about the intake. Whats the biggest size TB the stock lt1 intake can hold without porting?
Answer = 52mm (pretty sure anyway)
CARiD
Jan 27, 2015 06:27 AM
Jul 4, 2005 05:00 PM
Just making sure
