How to connect brake line to caliper
Old Feb 13, 2004 | 05:24 PM
94TA/GT's Avatar
Took the calipers off a few weeks ago to paint them.
Put em back on I can't remember how the brake line attaches back to the caliper.
Tried it about the only way it fits, but they leak air & fluid badly.
Can someone describe it or have some pics?
Help...
Thanks!
Old Feb 13, 2004 | 05:33 PM
94TA/GT's Avatar
Never mind...
I'm just an idiot....
Found the inside washers also.
Old Feb 13, 2004 | 05:46 PM
IrocSS85's Avatar
also an FYI, you can put the lines on the calipers backwards, so make sure the line is in the correct position and the flat side of the brass hose end is against the caliper. make sure you inspect them real good for leads when your done. and,you did know that those brass washers are one time use only right? if not, you have to replace them. they WILL leak if you try to reuse them.
chris
Old Feb 13, 2004 | 06:42 PM
94TA/GT's Avatar
Thanks,
Four new washers on and no leaks.
Jlo
Apr 3, 2015 10:32 AM
zxtce
Mar 12, 2015 08:06 PM
Jazsun
Dec 29, 2014 12:14 PM
kclarson
Aug 22, 2002 04:04 PM
