Throwout bearing
Old Feb 12, 2004 | 12:17 AM
meengreen 94z's Avatar
Throwout bearing
Im trying to replace my clutch, Ive disconnected the transmission and bellhousing, but the transmission wont slide out. The throwout bearing is stuck in place on the input shaft. I cant get the fork/release lever to come loose from on top of it. Is their something else required or was this probably the cause of my clutch not disengaging?
Old Feb 12, 2004 | 12:26 AM
Red96Lt1's Avatar
This happened to me. The clutch is a reverse pull clutch. You have to remove the clutch fork before you pull the tranny off. Remove the access plate. There is a bolt that is the fulcrum of the fork. Take it out and then slide the clutch fork out. It took me about 2 hours of prying to figure it out.
Old Feb 12, 2004 | 12:41 AM
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
