Permanent Cooling System Sealer?
Old Feb 15, 2004 | 02:00 AM
izzyz28's Avatar
Here's the deal. One of my head gaskets has a small leak. It only blows smoke when it's warmed up and idling or decelerating. I have seen "permanent" block sealer at the auto parts store, and was wondering if anyone has used this stuff. The motor is getting rebuilt in a cople of months, but i still need to drive the car for a while. Has anyone used this stuff before, and if so, is there a possibility that it will work in the short term. I know that it will probably clog up the heater core, and I'm prepared to deal with that. Any thoughts???
Old Feb 15, 2004 | 03:59 AM
MARZ's Avatar
don't use those coolant sealers, they reduce your cooling effeciency by coating everything, and clogging everything.
its not gonna fix a blown head gasket, get it fixed or get a beater
Old Feb 15, 2004 | 04:57 AM
joeSS97's Avatar
Change the gasket!
Old Feb 15, 2004 | 05:58 AM
scoobysnax83's Avatar
You have no options only a solution. The solution being to change the gasket. The more you drive it the worse it will get. There is no fix other than that.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
