installed a/f ratio gauge and now im stummped
i stalled it last night and all i get is the last bar lit up on the rich side. did i hook it up wrong? i also have a ses light on does the ses light mean that my o2's are probably bad? any idea's will be much appreciated.
Thanks Jason
Thanks Jason
How did you install the guage?
When just the last rich bar is lit, it means the guage is getting power, but no signal. What it seems is if you spliced into the O2 signal wire, you may have damaged the wire and the PCM no longer recieves signal from it.
I hooked mine up this way and it worked, but the guage really doesnt do much unless you have a wideband setup
well i didnt splice into the the wire i used one of those connectors that you put the wire through and then the wire you want tapped in there then you push down the metal tab in the center and it connects the two wire together any other help appreciated
Thanks Jason
Thanks Jason
Originally posted by importeater
Well those can still cut the wire if your not extreamly carefull. I used those on a A/F gauge install I did on a friends car and it didnt work the first time, i had to redo it.
BTW Craig, nice job on Nicks A/F Switch Setup. I would love to do somthing like that on mine
Id remove the connector you used to connect them, unplug that branch of the harness from the PCM, twist them together and then solder them. Use some shink tubing or E-tape to cover it up and your good as new. Just make sure the wires arn't too tight, you may need to add a short piece so there isnt tention on it, I forget how much slack is there.
Craig
Craig
Never mind with what I said above. Go to the parts store and ask them for the connectors with the solder already in them. All you'll have to do is cut the wire to the PCM, then stick all 3 wires in there and heat up the connector with a lighter. The solder in there will get hot enough and melt around the wires and the connector also shrinks with the heat. This is going to be the easiest. I've used them in my car and they are the absolute best.
could my o2's be completly shot or what because before i installed the a/f ratio gauge i already had a ses light on so could the o2's be gone? the performance of the car is not gone at all with the ses light on so what do you guys think?
Thanks Jason
Thanks Jason
Put a scanner on it and figure out what the SES light is for, rather than taking wild guesses and randomly replacing parts..... that's what we all condemn the typical dealer shop for doing. You should have scanned it and got rid of the SES light before you even started the A/F gauge install.
The last/rich bar being lighted may also mean its getting more that 1.0V from the wiring.... you did hook it to the purple (or purple/white) wire in the harness?
There is a harness that runs behind your engine under the hood. It'll have the black plastic harness wrap around it and might be taped up. Pull the tape off and find the Purple and white wire. Thats the wire from the drivers side O2 to the PCM. If you found the solid purple wire in a different harness, it is the passengers side wire from the O2 to the PCM. I used the Purple/White, because it was easier to get to and tap into since the gauge was going on the drivers side anyway.
I dunno, I NEVER use any type of t-taps and stay away from crimp-on connectors often too. Soldering is extremely easy and will NEVER come off.
