Where is the switch for the brake lights?
Old Feb 12, 2004 | 04:16 PM
dkeers's Avatar
I put a 700r4 in my '95 z28 and I need to get the converter lockup wired right. I had a switch rigged up on the brake pedal to unlock the converter when I hit the brakes but it isn't working out right. I need to know where the switch is for the brake lights to come on. I supppose I could also tap into a wire that gets power when the brake lights come on. Can anyone tell me where would be a good spot to tap into?
Dustin
Old Feb 12, 2004 | 04:50 PM
The switch is on the bracket by the pedal arm under the dash.
Old Feb 12, 2004 | 06:15 PM
dkeers's Avatar
Thanks. Do you know what wire is hot when the brake pedal is depressed?
Dustin
Old Feb 12, 2004 | 06:40 PM
In the grey connector, power is passed from the orange to lt blue wire when the pedal is depressed.
Old Feb 12, 2004 | 07:00 PM
dkeers's Avatar
Thanks a ton for the help. So the blue wire (on the grey connector) is "hot" when the pedal is depressed and "not hot" when the pedal is in its normal postion?
Thanks again,
Dustin
Old Feb 12, 2004 | 08:09 PM
Thanks again,
Dustin
That's right.
dluna333
15
Mar 13, 2015 12:30 PM
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
