Rough idle not smoothing out...
Old Feb 12, 2004 | 03:48 PM
95BlackTA's Avatar
I just replaced the opti 2 weeks ago with a used one. The used opti was previously in this car, but was replaced before it went bad...had about 40k miles on it.
Well about a week ago I had a coolant line leaking onto the opti. So I fixed the line, and the car was fine. Now I start the car today and its idleling pretty rough, so I drove it around hoping it woudl smooth out but it never did. WHen I accelerate it accelerates, but very rough....feels like its missing almost.
Im gonna be pisssed if I have to pull the damn opti again. Any other ideas I should try?
Oh yea, before I put that opti in, I ran a bead of RTV sealant around the entire thing, so I figured it should be water proof...
Old Feb 12, 2004 | 05:21 PM
95BlackTA's Avatar
I do have a Intake Manifold Leak...could that just be getting worse and making it idle worse?
Old Feb 12, 2004 | 07:04 PM
b-stevens's Avatar
It could be something as simple as not putting the wires on the right plugs... try tracing the wires again just to make sure. It happens to alot of people on this board.
Oh sorry I only read the first half of your post and figured id throw some quick advice and edit it later... Here goes my editing:
Nevermind, Im not sure what to tell you on that one... sorry
But it may be fine tomorrow, you never know.
Old Feb 12, 2004 | 07:07 PM
95BlackTA's Avatar
It ran fine for a few days...then all the sudden the battery dies after it sat for 2 days. SO I charged it and started it up, and now its running rough.
Old Feb 12, 2004 | 07:17 PM
b-stevens's Avatar
Well if your battery is dying after only 2 days of sitting... It could be that you need a new battery. Do you have a way of checking the voltage coming from the battery? Im sure we'll get slopokrodrigez in here, he seems to always chime in on these electrical threads
Old Feb 12, 2004 | 08:36 PM
95BlackTA's Avatar
Yup I got a multi meter..ill run out and see what its doing. But the thing is that the battery is like not even 2 months old. Brand new 170 amp alternator, and new belt....
The volts have been jumping around at idle, but i thought that was due to my intake manifold leak....or so ive been told.
When I start the car, the volts stay at around 14.5 volts until the car warms up and they start jumping around and dropping..
Old Feb 12, 2004 | 08:44 PM
95BlackTA's Avatar
Turned off, it was at like 12.50....Engine running it was 13.7.
Old Feb 12, 2004 | 10:22 PM
Wildwill2855's Avatar
dude its the pcv valve deal on the right side of the intake manifold the big rubber hosed end that is grey, i had the same problem it tore and sounded like my car was cammed i fixed it, i kinda miss it though when im running open headers
Old Feb 12, 2004 | 10:41 PM
95BlackTA's Avatar
Checked that and its fine.
pete53
Jun 27, 2015 09:08 AM
eagle54348
Jun 15, 2015 05:00 PM
markzzzz
May 8, 2015 09:21 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
