heater problem
Old Feb 13, 2004 | 06:21 PM
WhoomWhaatWhaah's Avatar
heater problem
No heat or A/C. Nothings happens when I turn the switch, nothin blowin? I checked the fuses, they are good.
Old Feb 13, 2004 | 06:25 PM
Red96Lt1's Avatar
Sounds like a vacuum problem to me.
Old Feb 13, 2004 | 06:49 PM
JKDZ28's Avatar
could be several things
id check vacumn first though
Old Feb 13, 2004 | 06:59 PM
JDBlaze85's Avatar
blower motor
can you hear the blower motor on at high speed down under the dash passenger side?
Old Feb 13, 2004 | 07:08 PM
bdc95ta's Avatar
I don't know much about ac but check to see if the compressor is engageing or not. It's the pully on the bottom drivers side you'll hear it and you can see it if you shine a flash light down there.
Old Feb 14, 2004 | 03:47 PM
I can feel the power loss when I turn on the a/c, so I think the compressor is working. My a/c worked fine before I changed out the heater core. How do I check vacumn?
Old Feb 14, 2004 | 04:02 PM
JDBlaze85's Avatar
if ur not getting air coming out the dash from bottom or top or middle.........the blower motor is not working!!!!!!
kksi
Feb 17, 2015 10:41 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Britbilly
Jan 7, 2015 08:49 PM
pologreen97z
Dec 2, 2014 10:42 AM
