hub
Old Feb 12, 2004 | 03:16 PM
akobak's Avatar
hub
Does any one know if a 98 camaro hub assembly will fit on a 94 firebird formula. need to know. just ordered one.
Old Feb 12, 2004 | 03:25 PM
BadAssed93Z's Avatar
if it does it will be one of the few interchangable parts from LS1 to LT1.
when you get it good luck.
Old Feb 12, 2004 | 03:28 PM
Tair's Avatar
I have a '95 hub assembly in my '94, so I guess it doesn't say much....but just to let you know, GM wanted an arm and a leg for it, so I went to the junkyard and grabbed one, works good.
Old Feb 12, 2004 | 03:31 PM
All_Z_Way's Avatar
If you are talking about a wheel hub....then yes they are the same.
Cheapest place I found them was O'Reily's or Autozone and still about $110 each.
Old Feb 12, 2004 | 03:57 PM
akobak's Avatar
hub
yes front wheel hub assembly ordered it from a yard close by. with shipping came to 40$. I was worried about the abs conection too. I guess ill find out if it works either tomorrow or the next day. thanks for the replies, ill post back to tell if it works. This site is very helpful, I was used to the third gen .org which was equally as helpful,I had an 86 TA I upgraded to the 94 formula lt1 ...what a difference!!!!!!!!!!!! opti and wheel bearing and i should be roarin.
Old Feb 12, 2004 | 04:55 PM
1993-2002 front wheel hubs are all the same.
Old Feb 12, 2004 | 08:20 PM
akobak's Avatar
thanks alot for the feedback.
AviatorDave
Dec 19, 2016 06:35 PM
Boss002
Jan 20, 2016 12:17 PM
Boss002
Jul 24, 2015 10:47 AM
RallyRed701/2
Jul 20, 2015 11:18 AM
cyteone
Feb 7, 2015 06:04 PM
