Easy ? what kind of tool for harmonic
Old Feb 13, 2004 | 01:24 PM
tim95z28's Avatar
Balancer? Need to pull mine off. Can you get one at autozone or such ?
thanks!
Old Feb 13, 2004 | 01:34 PM
Do you need to remove just the damper/pulley, or the complete assembly, including the crank hub? If its just the damper, in theory, you remove 3 bolts and pull it off with your hands. But if your car has more than a year or two of rust on it, you may need force to remove it.
Remove the three bolts on the three "arms" and see if it will come off. If not, soak the hub area well with a good penetrant like PB Blaster (WD-40 is not good enough). Then tap the inner portion of the damper with a hammer to see if it will come loose. If that fails, get a 3-jaw puller and mount it with the jaws pulling on the inside of the damper, not on the outside. Since the damper is made of two pieces, with a rubber ring in the middle, hitting the outer edge, or pulling on the outer edge can damage it.
If you are looking to pull the hub off the crank, let us know.
Old Feb 13, 2004 | 01:58 PM
ZDriver96's Avatar
I cant get my harmonic balancer off unless i use a puller. Doesnt matter how long its been on. Maybe im just weak
The 3 jaw puller will work but a bolt puller works better..
On your balancer you'll notice 3 bolt holes in between the bolts that hold the balancer to the crank. They are smaller bolt holes.
This is what it looks like
http://cgi.ebay.com/ebaymotors/ws/eB...category=43996
Autzone has it on there rent mat. Its near the center on the bottom row of tools. Its called a harmonic puller something.
Old Feb 13, 2004 | 02:39 PM
93ZM6Tally's Avatar
Autozone puller will work, but the bolts didn't fit. Got the right bolts from a hardware store and it worked fine. Three jaw is probably easier, and can also be used on the crank hub if you're doing anything besides just pulling the balancer to replace it.
Old Feb 13, 2004 | 02:43 PM
ZDriver96's Avatar
93ZM6Tally you didnt try to use the bolt holes that held the balancer to the crank did you? There are 3 smaller bolt holes your suppose to use.
Old Feb 13, 2004 | 03:51 PM
93ZM6Tally's Avatar
No. I used the smaller holes
Old Feb 13, 2004 | 03:56 PM
From what I have seen, only late model pulleys have the small "puller holes" between the spokes. If they are there, you can use them. If not, then umm, you can't.
Old Feb 13, 2004 | 05:00 PM
tim95z28's Avatar
Thanks for the answer, I am changing out the cam, so need to get everything off that is necessary to get the timing cover off.
TIm
Old Feb 13, 2004 | 06:16 PM
tim95z28's Avatar
OK I see I need to get the hub off. I cannot find a socket to fit the balancer hub bolt. I have 19mm and 21 mm but no 20mm it seems like it is a 20mm bolt. None of the english sockets I have fit, anyone know the size of the bolt?
Old Feb 13, 2004 | 06:57 PM
5/8"
marlar98
Sep 12, 2018 07:18 AM
themex2002
Sep 2, 2015 03:47 PM
karpetcm
Aug 14, 2015 03:02 PM
Aug 7, 2015 08:52 AM
Jul 17, 2015 02:47 PM
