Rearend problems
Rearend problems
There is a deep thumbing sound come from the rearend area from about 15mph and up, it only does it if your on the throttle, if you let off the thumbing goes away, it's a continuses sound when on the throttle. It a 96' TA WS6 A4 90K, 3.23 gears. if anyone can help just let me know.
thanks
chase
thanks
chase
If you pull the cover off and there is metal in the oil, thats not good... Or if you find big chunks missing from the ring gear.. that will tell you real quick. Probably a good idea to change the oil, and if you don't find anything, look else where. Sounds like you're going to find something though.
Just use a little common sense.. And don't forget to put friction modifier back in when you change the oil.
ddr698
Jan 31, 2015 10:58 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
