View Full Version : LT1 Based Engine Tech
- Things needed to run a LT1 on a stand..
- LT1 Ram Air Intake Questions!
- Oil Pressure
- Please Help: Opti or Wires
- Do I need new flywheel for my 96?
- Motor Question.....
- 96 Camaro Z28 start issues
- emissions delete and code 27 and 29..HELP!!!
- 121k miles and seems to run strong.
- waterpump drive shaft coupler
- another fan switch question... sorry...
- purge solenoid
- Switching from 1.6 Magnum Roller tips to full roller rockers
- Will this work with stock alternator?
- Removed damper from engine. Didn't note how it went on .
- coolant fan switch? 1993
- Lost optispark Driveshaft! help!
- cc306 is too aggressive , what are my other options?
- Couple of questions about rear intake oil leak
- 93 lt1 with 65,000
- egr valve source vacuum
- piston to valve clearance: will AFR 210cc heads 2.08/1.6 valves clear stock pistons?
- Hub-balancer question?
- oil filter removal
- How did you remove you're oil pan?
- 280XFI Cam
- Stock injectors with cam
- Checking pushrod length question
- Windage tray
- HV Oil Pump = trouble
- need opinions on v.r.e shortblocks
- Going to rebuild my 96 LT1
- Fuel injector
- Diagnosing Dead Cylinders
- broke ear on 1995 Z28 LT1 crankshaft hub
- Rock in my engine
- Cam found in spare lt1 motor
- Motor mount installation
- Replaced starter, but still wont start
- backfiring, dropping cylinders, etc.
- Need help quick! Starter/security problem???
- Water wetter vs dex cool 50/50
- Is a tune worth it for mid length headers/160 stat?
- Sharing some pics of my recent build... freshen up the 383sr, LTCC, Manual Rack...etc
- anyone have problems w/ water jacket leaks when using ARP studs?
- engine removal not going well
- Some advice for my project
- Need help!!
- 97 Z28 coolant leak driver side head!!!!
- 16 pin cable for lt1 tuning?
- anyone know anyone mod'ng lt1 fuel rails like this?
- rocker questions
- Help with vacumm line?
- LT1 < > LT4 starter ?
- Intake Gasket for Trick Flow Heads
- Two Pushrods vanished after 1.6 RR plz help asap
- Confused
- Comp Cam Pro Mag Question
- remind me what stock lt1 combustion chamber volume, head space, and piston dish size
- Okay, what could be the issue?
- Is this ok.
- 97 LT1 motor in a 94 Z28
- are these numbers ok? fuel pump maybe?
- What have I missed...
- 93-97 power steering pulley
- Old garage takes huge shortcuts on my old combo.
- Head gasket question.
- oil pressure
- Lt1 wont start code 36
- carb swap info
- cam installation? keep the old cam bearings?
- pcmforless vs madtuner
- rhodes v max lifters
- Fan Switch Mod
- What is the big deal with LS7 lifters??????
- tune question
- Dyno results 2/3/2012
- 96 camaro z28 seems to have poor top end power!!
- Removing EGR solenoid
- Good Pictures of engine bay needed
- LS7 lifters and shorter push rods question
- ARP head bolts or studs? which would you do?
- whats best method to clean/prep engine deck and piston tops for head gasket install?
- Beyond frustrated
- What's this hose for???
- Strange Vibe?
- stumped on this on going issue
- lt1 question
- Anyone else run a LT4 Hot cam with 1.7s?
- First build, need some advidce from the respected veterans.
- 383 crazy ish happened
- Howards Rocker Arms
- sbc rocker arms on lt1
- Does the IAC open at full throttle?
- have a lt1 problem need help
- stroker kit advice
- Missfire after heads and cam
- Lt1 engine question
- 40psi 3/4 throttle Intake backfire
- 98-02 LS1 Stock Lid with ram air box on lt1
- Not ideal i know but would this work alright
- Question about vented and non vented Optispark
- lt1 build help
- Question for you LT1 guys.
- can someone help me identify a genuine acdelco optispark from a knock off?
- Dynaspark vs. MSD OPTI
- gas mileage
- Lt1 clearance issue
- High idle lt1 please help!
- Heads/cam car wont start
- LT1 AC delect pulley. Having a few problems with it.
- Thank God for screwups!
- My 1995 Z28 might need a cap and rotor.
- Buying an OBD1 Scanner
- Valve spring help
- lonng tube or mid tube headers
- hot cam,comp cam 982 kit
- fuel feed and return lines 93 z28
- Fuel question
- Vibration
- Verify Opti is Delco / Deplhi
- Overheating Issue for the past 2 years!
- Lt1 slight mod question
- Lt1 lifter problem
- Is this the right part number for my MAF
- Help ASAP plz
- Starting problem
- cooling system question
- Balancing
- PROJECT 96 RS 3.8 5spd conversion to LT1 Auto 98+ front clip
- question about oil pan and timing chain cover gaskets
- DES connecting rods?
- Holy Crap I am BACK!!!!
- Steam Pipe on heads
- consequenses of not tuning after gear change?
- Clueless
- 94 LT1 engine problems
- can of rocks under my car
- WHats my next step?
- 396 lt1 what do you think? 4.037 bore
- cam question
- heads/cam/timing chain install
- how to remove shaft off of non-vented dist.
- 1993/1994 Opti question -- Opti seal?
- 94 m6 idle jumps then shuts off
- fans wont kick on
- Easiest engine swap. Top or Bottom?
- Oil Pan
- LT1 water pump problem
- got 2 engine blocks... what to do
- No Spark NEED HELP
- Which cylinder heads do you have, Stock or Other??
- 3.8 to LT1 on 96, AC question
- oil leaking
- drive belts
- are these good headers
- 97' lt1
- New Optispark on Firehawk, runs good a few minutes then...
- Next mod?
- Melted? Opti. What happened?
- Old 1995 Z28 - poor gas mileage
- Overheating
- 94 camaro rebuild questions
- changed 94 alternator to newer model type. Having issues.
- 96 LT1 hard start
- lt4 extreme duty timing chain? yay or nay?
- total engine airflow?
- 200 shot on top of 15psi blower possible?
- lt1 to ls1 swap
- Composite LT4 Valve Cover CCV Hose Options?
- OK boys lets talk nitrous. those that run 200 shot or higher lets see your setupo
- Oil leaking
- Swap of 96z engine into 95 TA help needed
- Why does my exhaust stink?
- Smoking at Idle
- Hard to start and security light on
- How to check for head casting # ?
- Will not go over 4000 rpms
- Engine/Trans mount help!
- Bad 02,wire,or just loose?
- Will not start/is it the dist?
- 1993 z28 LT1 Camaro Tuning
- 93 lt1 ... timing chain options
- Help, Minor Engine Failure
- AC Delco optispark source?
- bad optispark please help
- Need advice engine oil leak 1997
- LT-1 Differences PLEASE
- How to: hook up Deltran Battery Tender Plus to '93 to '97 f-body
- Trick flow heads?
- fuel injectors not receiving pulse from computer...
- 9.92@134.89
- rate these heads (hand ported)
- felpro sealed power Head Gaskets 260-1650
- Quick connect for msd 6al
- Bad mass airflow sensor?
- How to "peen" a washer onto an end of a shaft????
- 95 Z just shuts off.......Help
- valve train
- 97 SS pcv problem
- Oil Pan Leak?
- Valve Cover Gaskets "stretched"
- 95' Cooling Fan Issue
- How do I pull OBDI codes
- Not another 383 question (Yes it is)
- emissions help please!
- Fuel Pump (in-tank) - Rubber hose is melted??
- need to order pistons
- 94 Z28 Start up and take off issues???
- Harmonic balancer alignment LT4??
- Fuel leaking from transmission (flywheel area)
- SES light throwing code 62 oil temp sensor on 1995 z28
- 95 z28 engine light comes on when fans do but engine not hot?
- running one ported maf end and one stock?
- 97 T/A blowing PCM IGN fuses
- Driving and lost all oil pressure!
- Sparkplug swap finished!
- big block n a 94 camaro question
- tell me about forged cranks for the lt1....
- intake gasket?
- 1994 Z28 wont start. Need HELP.
- Cooler operating temps for an lt1
- 52mm TB on an M6
- need help with oil pressure sender sensor
- cat back
- Cracked Air Intake Elbow
- Rear main seal
- Z28 1994 Wont Rev past 700rpm
- are aftermarket lt1 fuel rails available?
- antifreeze reservoir spill/leak HELP!
- Hard start 1994 z28 camaro
- 97 lt1 head ans cam swap
- How much to rethread intake threads?
- will i get a code from deleting egr and air.
- Morel 5044
- NO spark z28 Please help
- Delteq Opti Box from inside pic.
- new here. i have a 94 z28 with 383 lt1 twin turbo
- Spuddering, misfire and knocking = corroded Opti-Spark
- what valve springs and roller rockers to use
- 1 7/8" headers on an LT1 possible? or stepped 1 3/4" to 1 7/8" headers
- Hub removal/installation
- LT1 impala waterpump on a LT1 camaro?
- 94 lt1 into 95 z28
- Optispark Experts: breakdown questions
- car just over heated, need some ideas
- Heads
- Main, Rod, Cam bearings Question
- 1.6 RR search
- Still Missfiring /:
