Hard start 1994 z28 camaro
Old Dec 21, 2011 | 10:47 AM
z28er_kgb's Avatar
I've been having problems starting my car recently, I have to crank it 2 or three times for it to start once it starts runs just fine. Any ideas of what i should check first or has anyone had similar issues? Someone told me it might be a dirty/clogged fuel filter but I'm not sure. It makes no difference if the engine is cold or hot either. Any info will be appreciated. Thanks in advance.
Old Dec 21, 2011 | 11:31 AM
Joe Bellman's Avatar
Re: Hard start 1994 z28 camaro
When was the last time the fuel filter was changed?
Old Dec 21, 2011 | 11:45 AM
z28er_kgb's Avatar
I'm not sure i just bought the car used a few weeks ago and the owner wasn't much help she said it was her brothers car. Does this sound like a place to start?
Old Dec 21, 2011 | 11:59 AM
In that case, I would change the fuel filter. Its cheap and pretty easy to do. I would also check the spark plugs and wires. It could be a failing opti too. Have access to a fuel pressure gauge?
Old Dec 21, 2011 | 03:01 PM
z28er_kgb's Avatar
I dont have access to a fuel press gauge unfortunately. I will change the fuel filter and the plugs, and post wether or not that fixed the issue. Thanks for your advise Joe Bellman.
Old Dec 23, 2011 | 01:19 PM
Michael T's Avatar
Check the coil wire ( looks just like a plug wire) sometimes it has tons of corrosion in the boot
Old Dec 23, 2011 | 03:49 PM
z28er_kgb's Avatar
Thanks Michael T. Will do.
Old Dec 23, 2011 | 10:12 PM
You can sometimes borrow a fuel pressure test gauge from your local parts store. You really need to check the fuel pressure, and see what pressure the system reaches when the pump stops priming after the first 2 seconds, and how fast that pressure drops when you turn the key back to off. Rapid loss of fuel pressure is a common cause of extended cranking for start.
Another check is to turn the key to "run" for a couple seconds, when the pump shuts off cycle the key rapidly to "off" and back to run. Repeat that process 3 or 4 times and see if it starts quicker when you turn it to "start". If it does, it would confirm that pressure loss is contributing to the problem.
Old Dec 25, 2011 | 03:20 PM
Steve0's Avatar
Say you are gettinga rapid pressure drop after the pump has primed. What is the fix? New pump?
Old Dec 26, 2011 | 02:53 PM
PLEASE don't highjack someone else's thread. If you need help, you have to start your own.
Noenav
Mar 1, 2019 07:38 AM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
thenewkid
Nov 27, 2014 09:41 AM
dreamer1q
Jul 24, 2002 04:39 PM
