Spuddering, misfire and knocking = corroded Opti-Spark
Looked at a lot of stuff on the internet and consistently found that this forum kept say the same thing. If the card has horrible knocking and back fire on acceleration, and the car is pulling crazy timing, then the opti-spark is fouled up. So i took it apart yesterday cleaned the contacts of the rotor and cap, put it back together and it runs beautifully!
Re: Spuddering, misfire and knocking = corroded Opti-Spark
Always check Shoebox for info like this:
http://shbox.com/1/opti_vacuum_hose.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_conn.jpg
