PROJECT 96 RS 3.8 5spd conversion to LT1 Auto 98+ front clip
Re: PROJECT 96 RS 3.8 5spd conversion to LT1 Auto 98+ front clip
I was cleaning it up a bit and couldn't resist taking the valve cover off to take a peak inside. I was told this engine has 8k miles on it. I don't know if this it true, but it looks pretty clean although someone could have changed the oil sooner because its pretty dirty.
I got the engine pulled out of the corner and after having to clean trans fluid off the entire garage floor
I got it set up and ready to work on cleaning it up.
I would replace those worthless plastic fuel lines with something better now that you have it apart. Mine burst on my 97 3.8 and were spraying fuel all over
the coilpacks got lucky no fire started.
here is what I did with my fuel lines.
https://www.camaroz28.com/forums/v6-...n-done-835946/
Nice work so far!
On a side note, I thought my car had the nastiest carpet before I replaced it. Looks like a tie hahaha.
Keep up the updates, love seeing builds like this.
During that ordeal I saw about a 2001 3.8 camaro at the junk yard and it had metal fuel lines that ran up up to the engine almost and did not go through the fender wells like a 97. Those might even be a better choice for you.
I have to find out if the lower control arms are bent or not. I think the drivers side may be bent. If so then I will have to use the ones off the other k member.
ChrisFrez
Jan 11, 2015 03:47 PM
