Steam Pipe on heads
Old Jan 19, 2012 | 03:27 PM
V8 LifeStyle's Avatar
Steam Pipe on heads
OK really fast my steam pipe broke in half so I was thinking to get two fittings on the back of each head to eachother so coolant can move from one head to another but im thinkning of removing the one that goes to the TB. My question is do I need to plug anything on the TB or can i just leave it open
Old Jan 19, 2012 | 03:45 PM
Re: Steam Pipe on heads
Not a good thing to do. The purpose of the steam tube is to allow steam and air bubbles to exit the flow from the dead end at the back of the heads. It's not there to allow coolant to flow from one head to the other. Without a way for the coolant to flow out of the back of both heads, and back to the radiator, you are going to run hot on cylinders #7 and #8 and may run into problems with detonation.
The system is in place for a very good reason. I would strongly suggest that you not remove the line from the back of the heads to the TB (which eventually goes to a connection on the radiator with a steam/air separator element).
Old Jan 19, 2012 | 04:42 PM
RamAir95TA's Avatar
If it broke in half (assuming it broke between the heads) just splice them back in with a piece of heater hose and a clamp after flaring the ends of the tubing.
Either that or convert to 1/4" NPT fittings.
Old Jan 20, 2012 | 06:21 AM
Ok perfect thanks guys. I'll most likely just convert it so it's looks nice
Old Jan 20, 2012 | 06:41 AM
There are some ideas in this thread.
If you want to bypass the throttle body with the coolant line, that is perfectly ok and routinely done.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
