cam installation? keep the old cam bearings?
Old Feb 5, 2012 | 06:41 PM
dizwiz24's Avatar
I'm swapping out the hotcam for a more blower friendly cam.
Motor is staying in car. I've got it all stripped down w/ heads off.
Anyways. Should i reuse the old cam bearings or install new cam bearings with the new cam I'm putting in?
63000 miles on the motor.
If I should reuse them, do you have any tips about pulling the cam out in a manner that won't trash the bearings?
Old Feb 5, 2012 | 07:17 PM
my1994z28's Avatar
Re: cam installation? keep the old cam bearings?
Cam bearings should be fine,just be careful when you remove the old cam..Just take your time and try not to bump any of them..
Old Feb 5, 2012 | 09:39 PM
You can't replace all the cam bearings with the engine in the car, anyway.
Old Feb 5, 2012 | 10:56 PM
RamAir95TA's Avatar
^ Yep. The motor needs to come out for bearing replacement. Clean and careful working conditions are paramount in keeping your current bearings in good shape.
Old Feb 6, 2012 | 11:02 AM
RUDEDOG's Avatar
When you remove the cam inspect the front bearing and change it if you see copper. Very easy to change.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
chuyz28
Nov 25, 2014 11:14 PM
GigaMp3z
Feb 20, 2003 02:57 PM
