Good Pictures of engine bay needed
Old Feb 2, 2012 | 08:49 AM
sandman2100's Avatar
I rewired my entire engine with a new harness and put in new heater hoses. Problem is, the engine was in disarray when I bought the car and even my best efforts have me thinking I have alot of things in the wrong places. I'e looked on Shobox's site (my bible) and I have a better idea on how the wiring on the manifold goes, but can't find anything close with the heater hose routing on the front of the engine.
I put the radiator and fans in last night and the hoses just seem stuffed in there, which I am sure is not the proper way. Does anyone have a good picture of that side of the engine with all the hoses / wiring ? Same for the power junction box (red plastic) It seems that just hovers there and I can't find a proper way to get it to stay.
Thanks!
Old Feb 2, 2012 | 09:13 AM
RamAir95TA's Avatar
Re: Good Pictures of engine bay needed
Everything you need is on Rob's webpage, including the heater hose routing.
Old Feb 2, 2012 | 09:21 AM
I have the locations to the pump correct, I mean how the hose sits around the radiator hoses, power steering lines, etc. Ergonomics, if it makes sense?
The pictures I see there don't really go where I need to see how each hose is routed from the top or bottom. It is either the end, or other shots with the fans out and the hoses disconnected.
Old Feb 3, 2012 | 06:03 PM
Are these not what you need?
http://shbox.com/1/heater_hoses.jpg
http://shbox.com/1/95-97_hoses.jpg
Old Feb 3, 2012 | 09:12 PM
No, those I have. Trying to find the best way to route them up front so it doesn't look like a bunch of snakes all tangled up. For instance, the heater hose on top is pushing the radiator hose so hard that it is up against the level sensor..... not sure how, so I wanted to see if someone had a good pic showing how they are situated in there.
May check local lots and see if they have car that I can "test drive"
Jazsun
Dec 29, 2014 12:14 PM
formula218
Dec 2, 2014 04:27 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
