94 lt1 into 95 z28
Old Dec 17, 2011 | 10:06 AM
tony wire's Avatar
94 lt1 into 95 z28
put 94 lt1 into my 95 z28 lt1 has auto trans. what do i need to do to make this work ?????????
Old Dec 17, 2011 | 10:25 AM
Re: 94 lt1 into 95 z28
Did you swap only the engine? Not the trans? The engine is virtually identical, except for the unvented Opti on the 94 engine (delete 95's vacuum and air supply lines, plug holes). If you also swapped in the 94 trans, you have to have the PCM reprogrammed for the on/off torque converter lockup used in 94 (95 is pulse width modulated lockup).
Old Dec 17, 2011 | 11:27 AM
tony wire's Avatar
i only swapped the the 94 motor into the 95 z28 sorry i didnt mention this new to this forum trying to get this running thanks for any info tony!!!!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
