Still Missfiring /:
Old Dec 15, 2011 | 12:09 AM
V8 LifeStyle's Avatar
Angry Still Missfiring /:
Hey guys my 95 z28 a4 I's still missing here are my upgrades and what I have changed and test i have done.
New parts- Coil(MSD streetfire),cap n rotor,wires,plugs( the plugs are clean and white since they have been on the car for less then 2000 miles)
Tried moving the injectors around to see if it was one of them that was bad, i also changed the cups and o-rings
Put a new egr I'n
Tried unplugging the O2- no change
Performance upgrades- CAI, Pullies, cat delete
Has an exhaust leak but always had it since i bought the car and back then it was running fine.
Any ideas on what to check next? ( i will be doing a compression test on sat) btw the heads were recently done by previous owner.
* the missfire gets worse as the car gets up to temp
Old Dec 15, 2011 | 05:47 AM
Guest47904's Avatar
Guest
Re: Still Missfiring /:
Have you identified the problem cylinder/cylinders?
Old Dec 15, 2011 | 08:52 AM
yea its either 6 or 8 its a poppin sound coming from the back passenger side
Old Dec 15, 2011 | 08:55 AM
the rpms stumble so i know its a missfire
Old Dec 15, 2011 | 03:42 PM
Guest47904's Avatar
Guest
Sounds to me like you have a loose plug. Had a friend of my sons think he had a lifter tick. Turned out to be a stripped plug hole.
Do you have headers?
Old Dec 15, 2011 | 07:04 PM
Nickw059's Avatar
Try unplugging each injector wire while running. if you engine stumbles when one is unplugged, than you know the unplugged one is good. if there's no change, than you found your dead cylnder.
99 z28 Haas
Apr 23, 2004 07:25 PM
street demon2k3
Mar 27, 2004 08:27 AM
eds96ragtop
Mar 5, 2004 04:43 PM
MattysTA
Feb 7, 2004 12:20 PM
ledfootz28
Nov 8, 2003 07:28 PM
