Okay, what could be the issue?
Old Feb 8, 2012 | 05:02 PM
Kalstar's Avatar
No it's not the opti!
Just reinstalled the engine (mild build LT1) with a remanned GM 4L60E. The car is a bolt on head/cam with 3200 stall (supercharger not installed yet). The only light on is the ABS, So the question......
The trans starts out in second and no matter what I do I can not get it into first. Is there a reason for this, maybe a limp mode or a bad trans computer? Could the stall be causing this or maybe the increased power without the dyno tune being done, confussing something....I am at a loss.
Update, I did replace the ECU if that makes a difference.
Old Feb 8, 2012 | 05:20 PM
Re: Okay, what could be the issue?
What codes show up with a scan? Trans codes don't light the check engine lamp.
Old Feb 8, 2012 | 06:35 PM
Kalstar's Avatar
The scanner I have does not go back that far (years). I figured maybe is was a common issue with a stall swap. Any guesses?
Old Feb 8, 2012 | 07:25 PM
calaban's Avatar
Nevermind... I re read your post.
Old Feb 8, 2012 | 11:10 PM
What year is your car?
Old Feb 9, 2012 | 06:29 AM
Kalstar's Avatar
It is a 1994 Z28.
Old Feb 9, 2012 | 11:08 AM
It is a 1994 Z28.
You need a "real" OBD-I scanner, or scanning software specifically for the 94/95 LT1. You can sometimes find decent older used Auto Xray OBD-I scanners on ebay.
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
