Lost optispark Driveshaft! help!
Old Feb 21, 2012 | 02:37 PM
greenformula94's Avatar
SO its missing... I googled it, and noone seems to sell one...
I seen one on ebay, but it was used and obviously outrageously priced...
Anyone got one that can help, or anyone know someone that sells them?
I know that gm has no seperate item number listed....
Old Feb 21, 2012 | 03:58 PM
Re: Lost optispark Driveshaft! help!
Advertise in parts wanted forums.
pgerst's Avatar
optispark driveshaft? Do you mean the driveshaft for the water pump (10219554) or the coupler (10128334)? I think the only way to get the driveshaft out of the optispark body is to press it out; if you lost that you may be able to buy an opti with bad sensors and cannibalize it for bearings and shaft?
Old Feb 21, 2012 | 04:05 PM
The splined opti drive stub will come off a stock opti.
Old Feb 21, 2012 | 04:20 PM
pgerst's Avatar
interesting, did not know you could take that off the earlier version; guess I will chalk that up as one more "improvement" GM made to the non-vented opti.
Old Feb 21, 2012 | 05:03 PM
usually people with old optis will have one laying around....
Old Feb 21, 2012 | 05:30 PM
Not only does it pull out of the back of the Opti - it has the same spline pattern that needs to be aligned in the back of the Opti, just like the other end gets aligned in the cam sprocket.
Old Feb 22, 2012 | 12:36 PM
pgerst's Avatar
No wonder why everyone has such a hard time putting the unvented versions back in correctly.
Old Feb 22, 2012 | 04:01 PM
craby's Avatar
did you look in the cam? lol, ive done that changin a opti, lookin around and found it where it was suposed to be. i have one somewhere around here,,,, cant find the dang thing. i switched to a vented style cam setup so i know i have one. have not seen it in a year though so may take a day or two to find the thing. looked but cant find a part number for it. i seen the one for 20 bucks on ebabe, looks like it has a pretty good grove. could be the picture.
Old Feb 22, 2012 | 05:23 PM
Well the one on ebay is 27.50$ shipped....
I just got one from a guy on ls1lt1.com for 15.75$ shipped.
So thanks everyone for the help, but i got one.
blac94Z
Nov 4, 2015 01:59 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
colts0455
Sep 27, 2015 01:07 PM
HAWG
Sep 25, 2015 11:41 AM
