Cracked Air Intake Elbow
Old Dec 21, 2011 | 11:27 PM
Jordan '94 Z28's Avatar
Does anyone know of a replacement part for a elbow for a 1994 Z28 LT1 Camaro? Trying to find one. In addition I'm wanting to purchase a performance cold air intake kit, are there any that replace the entire stock system?
Thanks.
Old Dec 21, 2011 | 11:42 PM
Bersaglieri's Avatar
Re: Cracked Air Intake Elbow
Cold air kits replace from the MAF to the filter. I recommend Lingenfelter over others. The elbow from the throttle body to the MAF can also be replaced. Check Summit for trickflow, 1LE, and Vortec elbows.
-Dustin-
Old Dec 22, 2011 | 08:47 AM
GM 25147210 for a 94 with non-vented opti. This elbow has no silencer hanging down (1LE type). It comes with new IAT sensor.
Old Dec 22, 2011 | 10:58 AM
Thanks for all the info guys. Not too keen on the whole duct tape idea....I like to take my Z to car shows would probably lose points. The GM part # was very helpful thanks!
Old Dec 22, 2011 | 11:34 AM
crazypurgatory's Avatar
Lightbulb Re: Cracked Air Intake Elbow
I would also stay away from the cheap EBay elbow's.
I got one and had to return it.
It have very bad fitment problems.
Old Dec 22, 2011 | 11:55 AM
pgerst's Avatar
The 1le is your best bet, you can find them new for less than $100. No snorkel and smooth inside so flow better than stock; also rubber so do not heat soak the incoming air like the metal ones do.
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
rjc1629
Jan 27, 2015 10:46 AM
slothgrant
Aug 22, 2002 03:01 PM
