cat back
Re: cat back
For the most part, they all make around the same power. Its more sound preference to you. Hit up some cruise in's or local get togethers and listen. You'll find one that sounds the best to you and go from there.
Re: cat back
Consider the Borla adjustable or the Loudmouth. The key is to make sure the intermediate pipe is at least 3.0" mandrel bent. That's where most of the improvement seems to be found.
There are also 3.5" and 4.0" catbacks, but they are generally used only in higher HP (450 flywheelHP and up) applications.
Re: cat back
My preference is GMMG. It's chambered exhaust and has an excellent, deep, muscley sound.
This is a great resource for comparing the sound of different exhaust options: LS1 Sounds - Your Comprehensive Exhaust Resource
Jul 4, 2005 05:00 PM
