Oil Pan Leak?
Old Dec 30, 2011 | 07:45 PM
silverz28's Avatar
Oil Pan Leak?
I have a 383 LT1 with a Canton Oil Pan (242T). I have changed the gasket twice and it is till leaking oil. The gasket is a Felpro and I put RTV on the ends where the gasket meets the block, not where the gasket meets the pan. I can't seem to get rid of the leak. Looks like it is coming from between the gasket and pan not the gasket and block ( where it has RTV) but not sure. Should I get a different oil pan? Could it be front or rear crank seal, how can I tell?
Old Dec 31, 2011 | 06:40 AM
Guest47904's Avatar
Guest
Re: Oil Pan Leak?
Did you check crankcase vacuum level? Today most cars leak due to bad PCV systems.
Old Dec 31, 2011 | 09:17 AM
silverz28's Avatar
Re: Oil Pan Leak?
I don't have a vacuum tester but the pcv is all in tact.
Old Jan 1, 2012 | 06:25 PM
Guest47904's Avatar
Guest
Re: Oil Pan Leak?
But does it work? If it allows air in both directions the crankcase will not have the required vacuum level.
Old Feb 29, 2012 | 03:23 PM
96LT1TX's Avatar
Re: Oil Pan Leak?
How would one test this? Will start search now.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
