Cam found in spare lt1 motor
Old Feb 16, 2012 | 11:55 AM
undecidedfbody's Avatar
Hey guys I was board today so I ripped apart a spare block I have and found a cam with some engravings. I proceeded to do a google search and came up empty handed. So I could use some help. Here it goes......
3313/3315 engraved with dremel
HR114+4 also with dremel
U5217-10 also with dremel
4615yn with factory engraving
Thanks for the help
Old Feb 16, 2012 | 01:48 PM
96capricemgr's Avatar
Re: Cam found in spare lt1 motor
Looks like Comp Extreme energy lobes
218/230 lift is .495/.510 with 1.5s
HR114+4 Probably means 114 LSA and 4degrees advance ground in
Really mild duration and lift, really big intake/exhaust split, ridiculously wide LSA which either means an ignorant emissions grind(112 would have been fine that mild) or maybe it was for boost.
Might be interesting to see what it would do with a turbo and some 1.6 rockers.
Old Feb 16, 2012 | 02:18 PM
I dont really need it so I guess I'll put it up for sale
thank you
Old Feb 16, 2012 | 04:26 PM
Large split and 114LSA might also indicate a nitrous cam.
Old Feb 16, 2012 | 05:14 PM
Thanks fred I will include all this info in my for sale post thank you all for your help
Old Feb 16, 2012 | 06:17 PM
Bersaglieri's Avatar
That is a somewhat common Comp Cam blower cam. Xtreme Energy HR Lobes as Dwayne said: 218/230 .528/.544 [1.6] 114LSA 110ICL
Thunder Racing sells this cam as a blower camshaft.
-Dustin-
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
1LEThumper
Jul 14, 2003 12:45 PM
HuJass
18
Jun 24, 2002 09:19 PM
