Going to rebuild my 96 LT1
I am going to pull my engine from my 96 ss M6 and gonna rebuild it and do some upgrades. I don't think Im going to do a stroker but I'd like to do camshaft, rockers, port heads and intake, throttle body upgrade. My questions are... What do I need to do as far as machining? Bore the block? Deck heads? intake? have the shop check the crank shaft? If anyone could give me some advice here I'd appreciate it. Im also having the trans rebuilt so I'll be dropping it out first then using a happy hooker hoist to pull the motor from the top.
Re: Going to rebuild my 96 LT1
What are your end HP/ET goals? Have you done any parts selection? Why are you rebuilding in the first place? Is your current bottom end toast?
There's a really great book on rebuilding the LT1 engine:
Amazon.com: How to Rebuild Small-Block Chevy Lt1/Lt4 Engines Hp1393 (0075478013937): Mike Mavrigian: Books
Find a GOOD reputable machine shop then discuss machining options with them. They will know exactly what to do and will be happy to discuss pricing.
Why go 383? Unless something exploded I'd rather reuse the factory bottom end with a few small fixes and build a real nice 355. I'm building a mild 355 for my daily driver car, should be 425-450hp at the crank and I see no reason to add cubes.
Hope this helps, I should amend this with more info since the build is done.
https://www.camaroz28.com/forums/lt1...-build-732013/
-Dustin-
-Dustin-
-Dustin-
-Dustin-
[QUOTE=camz28ryan;6875843]Drop the engine from the bottom instead of pulling it.. Just my opinion.[/QUOTE
Is it a ton easier? Never pulled an engine out of a car before. Would it be possible to pull it out the bottom in a garage at home? No lift or anything.
There are several threads discussing engine removal, with links to procedures for dropping the engine out the bottom. Here's a couple links:
Engine Removal
http://www.cardomain.com/ride/348183...-camaro/page-6
Engine Removal
Engine Removal
Engine Removal
This. Make sure you're not getting half-measures like knurled guides and imported cheapo parts. You want the block to be torque plate honed, decked, line honed if needed, the crank should be sized and checked for straightness, heads should be fully rebuilt with new parts and a performance 5 angle/radius valve job.
Sergio
Jan 27, 2016 04:27 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
