Help ASAP plz
Old Jan 21, 2012 | 08:07 AM
V8 LifeStyle's Avatar
Help ASAP plz
I snapped one of the three ARP bolts that hold the sproket to cam.
(the torque wrench I have sucks) can I still run it with 2APR with lots of threadlocke and a lot of luck lol. I won't be running nitrous and if I do it won't be for a while like a long time.
Old Jan 21, 2012 | 08:40 AM
Re: Help ASAP plz
Absolutely not. You need to repair it correctly.
Old Jan 21, 2012 | 08:50 AM
jloshotz's Avatar
Drill it out, take your time with an extractor kit and a good/correct size drill bit (being sure to keep shavings contained). It isn't that difficult, and you will thank yourself later
Old Jan 21, 2012 | 09:10 AM
Re: Help ASAP plz
Should i take the cam out of the car
Old Jan 23, 2012 | 01:29 PM
Smith.justin51's Avatar
Re: Help ASAP plz
Drill it out better to do it right then half a** and regret it in the long run
Old Jan 23, 2012 | 07:46 PM
andysc's Avatar
Re: Help ASAP plz
If you don't feel comfortable drilling it out, take it to a machine shop. They may or may not overcharge you, but at this point you need to have this addressed properly. So yes you can take the cam out of the engine and have it fixed.
tia
andy schuck
Old Jan 23, 2012 | 07:52 PM
kartracer13's Avatar
Re: Help ASAP plz
If you do do it yourself,grind the tip of the twist drill (drill bit) to about 20 deg. that will cut that hard metal easier.
Old Jan 25, 2012 | 08:31 AM
Re: Help ASAP plz
yea i took it out of the car (stupid question but w/e) drilled a hole in the center took it to ace where i know the manager and he drille dit out for me and the cam is back in with three bolts and almost ready to crank her up 2nite hopefully. thanks guys
colts0455
Sep 11, 2015 06:16 PM
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
Jmj93z28
Jul 8, 2015 10:01 PM
