cam question
Old Jan 17, 2012 | 07:14 PM
94magh's Avatar
cam question
i want to install a cam in my 94 z..really want to go with the 847 bc i love the way it sounds...my question is can i get by just installing the cam and some springs or do i need to do other things to make this work...dont know a whole lot about these motors just a lil..so all of u guys help will be helpful to point me in the right direction...just want my car to hit hard and sound good not for racing..its a daily driver
Old Jan 17, 2012 | 07:32 PM
V8 LifeStyle's Avatar
Re: cam question
if its not for racing just take the cat off and put a pipe in its place thats what i did and it sound nice not too loud but loud enough when you go wot and it backfires nasty style too or just do exhuast. Im installing cam and heads as we speak, from what i read the stock heads can only handle the stock cam, thats what i understood.
Old Jan 17, 2012 | 07:38 PM
raulz28's Avatar
From: 5 minutes from the warzone in mexico(south texas)
Re: cam question
The gm847 makes it's power at a very high RPM, you will need some head work done to really make it shine, and if you are staying with the stock bottom I would say it might be too much cam for your setup. The cc503 is the cam that several people have chosen for a stock head car with very good results.
Old Jan 17, 2012 | 07:41 PM
raulz28's Avatar
Re: cam question
I don't know where you read that but there are several cam only LT1s with good results without doing heads.
Old Jan 17, 2012 | 07:44 PM
Re: cam question
i forgot too but it im not complaing it made me buy new heads with a cam so it worked out fine lol
Old Jan 17, 2012 | 07:52 PM
96capricemgr's Avatar
Re: cam question
If you want the lopey sound on an otherwise stock engine you would be better served with s shorter duration can on a tighter LSA
Old Jan 17, 2012 | 08:42 PM
Kevin Blown 95 TA's Avatar
Re: cam question
I think they even got some new cams that make a lopey sound and don't mess up your driveability, although that's a lot of trouble to go through for a lopey sounding car.
Old Jan 18, 2012 | 11:20 AM
94magh's Avatar
Re: cam question
i appreciate all the tips and help...,,,my ultimate goal would be to build the motor if i had the money and my steup would be le2 heads,847 cam,ported intake,355 bottom end,3000 stall lts wit ory pipe and some 373s
Old Jan 18, 2012 | 11:23 AM
Re: cam question
You are still not getting it, even your dream setup there is not right, the 847 is going to want more stall and/or gear.
Old Jan 18, 2012 | 10:03 PM
Gtpguy's Avatar
Re: cam question
You can lower your idle speed with a simple tune to make it sound like you have a cam. I mean if you aren't going to race it, then why spend the money.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
