Quick connect for msd 6al
I need to order a quick connect harness for my msd 6al. I originally just cut/spliced the wiring harness in order to make it work but would like to clean up the wiring with the quick connect. Does anyone know where I could order one for my 94z28 on the cheap?
Re: Quick connect for msd 6al
I gave Summit a call today to see if they could point me in the right direction. Apparently msd has discontinued the 6al so they don't have any of the part numbers in their computer data base. The tech told me if I had the instruction manual all I would need to do would be to grab the part numbers that I require and he could look them up from that. If only I would've spent the extra $25
8 years ago I could avoid this whole situation.
Yep, I definately already have that (good news). I was trying to track down an electrical issue which turned out to be a defective msd opti (early model). Is the larger connector of the quick connect harness(2 dual prong) plug into the msd connector. If that's the case that's where my problem lies because I couldn't figure out where that portion went. Obviously the single two prong is going into the coil.
Drtryder
Apr 22, 2015 04:17 PM
