95' Cooling Fan Issue
Old Dec 30, 2011 | 05:22 PM
Meen95z's Avatar
Question 95' Cooling Fan Issue
I have a 95' trans am A4 and recently my fans just quit working. I have a manual fan switch also and that wont work either. I have the fans set to come on at 165 degrees also. This is what I have checked:
-Relays
-Fuses
-Grounds
I also recently have my ignition switch took a [edit], but the car runs most the time, dies once in awhile. Would anything on the ignition switch affect the fans? Any ideas?
Last edited by Injuneer; Dec 30, 2011 at 06:11 PM. Reason: Please don't override the language filter
Old Dec 30, 2011 | 06:13 PM
Re: 95' Cooling Fan Issue
Did you check the fusible link?
http://shbox.com/1/1995_pcm6.jpg
In the reference, all 95's are "late production".
Old Dec 30, 2011 | 06:46 PM
Meen95z's Avatar
Fixed it, its kinda stupid on my part. On the side of the ignition switch you have 2 plugs, the blue plug and brown plug. The brown plug was not snapped in. double checked that and snapped it in and the fans worked again. Everything is back to normal. So for future reference, the brown plug controls fans. Thanks for the quick reply..
Old Dec 30, 2011 | 07:10 PM
Not exactly. What you had was some fuses not getting power because the connector was not plugged in fully. One of them happened to be for the fans. Anyway, you got it fixed.
Magenta_Hearts
Mar 29, 2017 08:54 PM
grabbem88
Apr 16, 2015 06:57 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
IrocSS85
Jul 18, 2002 10:35 PM
