WHats my next step?
Old Jan 17, 2012 | 07:52 PM
GMC5.3's Avatar
WHats my next step?
Ok Guys please help me make this decision here, i believe i may have stripped the steam pipe thread on my driver side, i converted to AN fittings while the engine was in and now i cant get a 1/4NPT steel nipple to thread in with ease. My question to you is should try and chase the thread if its even possible being that the engine is in the car. Or do i have to tear the whole thing apart again to take the cylinder head off. Thanks for your time
Old Jan 17, 2012 | 08:39 PM
GreasyB's Avatar
Re: WHats my next step?
You can take the cylinder heads off with the engine still in the car. I have my doubts you can fit a thread chaser in there with the engine in the car though. So you converted the steam pipe to AN?
Old Jan 17, 2012 | 09:01 PM
GMC5.3's Avatar
I know I can take the heads off but do I need a new manifold gasket and cylinder head gasket? I'm just hoping I don't have to go that route....Hoping, yes I converted, lots of write ups on it just did it too late and not while I did my headgasket swap
Sent from my SGH-T839 using Tapatalk
Old Jan 17, 2012 | 10:10 PM
Yes, you will need to replace the gaskets. It will be a difficult repair, because you cannot see much of what you are doing (maybe why it got stripped in the first place).
Old Jan 17, 2012 | 11:07 PM
GMC5.3's Avatar
Thanks shbox, what i was looking for , oh and any idea on where to buy the npsf tap, harbor freight and or oriellys didn't have it
Old Jan 20, 2012 | 08:35 PM
GMC5.3's Avatar
i did get to start the car finally today with out any check engine light or leak. I did notice an unusual amount of smoke coming from the engine, anybody experience this before. We are talking about 5 mins of idle time and engine smokes, car hasnt been started this long since the headgasket swap and has been sitting awhile.
Could the smoke be from me capping the dip stick tube hole out of the oil pan, During my head gasket swap i couldnt get the tube back in and ended up breaking off the tip so i just capped it?
Old Jan 20, 2012 | 09:15 PM
kartracer13's Avatar
Is an AN fittings pipe thread??? I just assumed that the threads were normal machine threads.
Old Jan 20, 2012 | 10:38 PM
Powersource's Avatar
Smoke from where on the engine? If you leaked oil everywhere, if could smoke for awhile.
Old Jan 20, 2012 | 11:00 PM
GMC5.3's Avatar
i may have, i just dont want to ruin anything, i wanna try and drive it to autozone to use their scanner but just make sure i wont hopefully ruin anything further, thanks for your post
Old Jan 21, 2012 | 12:18 AM
I would first try to verify where the smoke is coming from before driving it. Like you said, better not to hurt anything.
Generally after I do anything major, I let the car idle and verify proper functions like water temp, idle speed, check for loose hoses, leaks, check engine lights, etc.If all is well, then I take it for a little shakedown cruise, come back and after a cool down check bolts again, look for more signs of leaks.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
WobblySausage
Oct 7, 2015 02:44 PM
Bxlt1
Sep 17, 2015 08:31 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
