emissions delete and code 27 and 29..HELP!!!
Old Feb 23, 2012 | 05:56 PM
95z28cammed's Avatar
hey everyone i have a 95 z28 that the previous owner had gotten rid of the emissions and put the metal plates on...the car detonates likes crazy and i bought an actron 9145 and the scan codes are 27 and 29, both dealing with egr and airpump? my question is was the emission delete done wrong? do i need to reflash the computer to delete emissions?....thanks for the help
Old Feb 23, 2012 | 06:05 PM
carboncamaro's Avatar
Re: emissions delete and code 27 and 29..HELP!!!
Yes you definitely need to get the PCM reprogrammed to tune those out.
Old Feb 23, 2012 | 06:45 PM
thanks for the info man,do u have to send it out to a shop or can u buy something that does it
Old Feb 24, 2012 | 05:23 AM
On the 93-95 OBD-I cars, you can prevent DTC 27 (EGR solenoid) by sticking a 2,000 ohm resistor into the pins of the harness connector for the solenoid. As long as there is a good fuse and a good relay in the circuit for the AIR pump, you should not get DTC 29.
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Jason Short
Jan 19, 2015 06:34 PM
lax037
Aug 18, 2002 02:07 PM
ssfirefighter
Aug 17, 2002 03:19 PM
91Bird305
Aug 5, 2002 01:39 PM
