Checking pushrod length question
Old Feb 17, 2012 | 09:25 PM
bowtiedad_z28's Avatar
Do check it at zero lash or or with the preload? Also should i use 1/4 or 1/2 turn after zero lash? I am sure i will get different opinions on this but let me hear them.
They are oem lifters and 1.6 rockers. Of course i will also be using a solid lifter to be checking it with as well as starting on the cams base circle. I have seen where guys have done it with and without the preload. I just want to know which is actually the correct way to do it.
Old Feb 17, 2012 | 09:43 PM
camz28ryan's Avatar
Re: Checking pushrod length question
Depending on what lifters you have will determine pre load. Comp lifters are 1/8 pre-load. FYI, based on my expierence with the site you will get better answers and quicker if you have your car info in your signature. Just makes it easier for the moderators.
Roadie
Feb 16, 2015 10:34 AM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
