96 camaro z28 seems to have poor top end power!!
Old Feb 3, 2012 | 12:01 AM
clean_z28's Avatar
i have a 96 camaro z28 just seems like it loses power in the higher RPMS, i just changed out the optispark and plug wires the other day, helped out a little but has poor top end power! it has decent low end power but poor top end! before i changed out the optispark it ran perfect when engine was cold could spin tires first trough second but when it warmed up it ran like crap. now after i changed the optispark it runs smoother but doesnt have the power it did before when the engine was cold? any info would helpp!!!!
Old Feb 3, 2012 | 07:51 AM
jon_7687's Avatar
Re: 96 camaro z28 seems to have poor top end power!!
Is your check engine light coming on?
I would look at your sensors, especially your O2 sensors. Sounds like somethings not giving a proper reading when your car warms up and goes into closed loop operation.
Mine did the same thing. It would run good until it warmed up, then run terrible. After a few min of running bad it kicked on the check engine light it would run OK again. Turns out my passenger side O2 sensor was bad. Changed that out and its run perfect ever since.
Old Feb 3, 2012 | 10:13 AM
mrmint69's Avatar
Have you checked fuel pressure while driving? Might be weak pump or plugged fuel filter.
Old Feb 3, 2012 | 02:11 PM
clean_z28's Avatar
well it runs the same now while cold or warm sense i changed the optispark, but still doesnt really have top end power, i did have a check engine light on it was p1153 which im pretty sure thats bank2 sensor1 which is passenger side right? but then i cleared code and hasnt came on sense? so it might need changed still?
Old Feb 3, 2012 | 03:00 PM
GRIDERMAN87's Avatar
have you checked fuel pressure/ changed filter as mentioned above?
Old Feb 3, 2012 | 04:34 PM
clean_z28's Avatar
no havent checked fuel pressure yet ill do that asap
Old Feb 3, 2012 | 05:41 PM
Do you run cats? Possible that one or both is plugged up?
Old Feb 5, 2012 | 02:58 AM
clean_z28's Avatar
yes but im pretty sure there is only one cat!
Old Feb 5, 2012 | 09:57 AM
But if it's a 96, it left the factory with two cats. How did you eliminate one of them?
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
carcrazyQT
Sep 3, 2002 02:51 PM
dreamer1q
Jul 24, 2002 04:39 PM
Jake77444
Jul 21, 2002 05:37 PM
